Thank you! Will look into it for more infoThe Keyboard Oracle wrote:The Keyboard Oracle has decided: The desired keyboard is possibly still available as a custom order.
The Keyboard Oracle has decided: The Ducky DK9008 Shine Keyboard with Blue LED, Cherry Brown switches and Mac compatibility over USB.lieiti wrote:1. MX Brown switches (or whatever is best for typing)
2. Illuminated backlit keys (blue preferably)
3. USB connectivity (integrated USB port preferably)
4. Mac compatible (with Mac key options preferably)
The Keyboard Oracle has decided: The QPAD MK-85 with Cherry Brown switches and ISO layout.ViXoZuDo wrote:Oh, my great oracle! I have simple requirements:
The Keyboard Oracle has decided: The KeyStone adapter from Silicon Valley Bus Co. and the Cherry G80-1800.bhtooefr wrote:ADB interface
Cherry blue or clicky+tactile Alps
Compact layout please, but needs a numpad
ANSI enter and backslash, no funny business there please
Inverted T arrow keys
Does not need function keys, but it can have them
The Keyboard Oracle has decided: The Ducky Shine DK9008S.Cronax wrote:Oh great oracle, hallowed be thy name, I come to thee in my time of need.
My wishes are as follows:
- Maximum budget of 150 euros with shipping (I am European)
- US 104-key layout (Full layout)
- Backlighting preferred
- Cherry MX Browns
Oh, Oracle, are there any options that are native ADB? It looks like that adapter is unobtanium, and I'd like the reset (II)/power (Mac) key on the board itself, you end up pressing Open Apple+Ctrl+Reset too often to have it on the adapter.The Keyboard Oracle wrote:The Keyboard Oracle has decided: The KeyStone adapter from Silicon Valley Bus Co. and the Cherry G80-1800.
The Keyboard Oracle has decided: The Raptor Gaming K1 with ISO layout and NKRO.huttala wrote:Oh great oracle, I need a Cherry board (or any other board that is not plate mounted) with 6KRO or NKRO.
I have an G80-8113 right now but it's to big for me, I need a smaller one.
What should I buy ?
Switches doesn't matter since I got all the switches I want at home and will just swap the switches that I want.
I need to be able to get it shipped to Sweden as well, ISO would be prefered, but ANSI is no problem at all.
The Keyboard Oracle has decided: A keyboard with the exact desired configuration is not known in the conscious and vast mind of the Oracle. You need to compromise or modify.bhtooefr wrote:Oh, Oracle, are there any options that are native ADB? It looks like that adapter is unobtanium, and I'd like the reset (II)/power (Mac) key on the board itself, you end up pressing Open Apple+Ctrl+Reset too often to have it on the adapter.
