Is it possible to have sticky threads a little bit more obvious than regular ones? I can almost never tell the difference
Suggestion 2:
Can you move the thread creator under the title, make the thread creator text smaller, or something that will make it more obvious which is the thread name and which is the thread creator? On multiple occasions, I've clicked on the user name and gone
