So I picked it up from the sellers place and found out that this Keyboard has really old Cherry Switches and doubleshots !
After some Internet search i found out what Btx realy is and that these boards where produced in 1984 (http://btxmuseum.de/Hardware/geraet.asp?id=144). This board is longer on the world than I am.
The keyboard I bought has a bunch of cables hanging on the outside connected to 2 rs232 Ports. Not quiet normal.
After opening up the case it was clearly seen that the time has done some serious damage to the keyboard.
Someone has done many scratches on the PCB and someone else did some heavy cable soldering to try to get the keyboard running, unfortunately I don't know if the soldering has made the keyboard running because my pc don't has rs232 ports.
If the case hadn't this strange layout it could be used fore some modding also some of the switches are also damaged and the working ones felt kind of not right
But all in all I am really happy with those thick old vintage cherry doubleshots
Random placing of the keycaps after the dismounting ... I wanted to go sleep
4 Sorts of keycaps ... sort of a catch em all Keyboard
Still don't get the spacebar fit into its place with the stabilization ... this thing is going to make me mad
Some IC's:
