False_Dmitry_II wrote: All you'd need to use on a computer is a case and a controller.
yeah sethstorm converted his WW.
the actionwriter arrived in '85 but the wheelwriter was available before Q4 1984 (
source). XMIT has a WW keyboard from mid 1984, showing that the buckling spring over membrane design did not originate on the enhanced keyboard. This might be the earliest known buckling spring over membrane KB as the source says the Wheelwriters were "new" in mid-december of '84, and his is from much earlier (though it's just an assembly and *might* have come from a different typewriter. THis is why I want to explore the early-to-mid 1980's IBM typewriter design)
Now I wan to see what KB the IBM electronic typewriters (65,85,95) used in ~1982 as they are a fusion of selectric and something else. I only see one
youtube video on these and it doesn't have a good shot at the KB. All I do know is that it appears to have a PCB and *might* be capsense (model F).
vivalarevolución wrote: These are fun, the feel seem like between an M and F, and I think a couple people have made them work.
interesting. They are pretty much identical to a model M, though some have o-rings around the barrels, possibly to help bottomout. When I
bolt-modded my Wheelwriter KB (10 series II) the take apart shows almost identical construction to model M (though I believe the shifts are linked on the WW KB). I am happily using my bolt modded WW KB with the WW it came attached to. I mainly use it for addressing envelopes.
