Belkin n52te
- elecplus
- DT Pro Member: 0082
Has anyone here used one of these? I found one at the recycler, and it works perfectly on Windows 7 after I downloaded the software from the Belkin website. I am not a gamer, but it intrigues me!
- DT Pro Member: 0167
I have one
They ain't bad as domes go but i no longer use it.
is it the belkin one or the razer branded one ?
I
I
- elecplus
This one says Belkin, but the software is Razer.
same one as mine then, if only it was a mechanical
i have seen someone mod one but i cannot be bothered doing that
as domes go its not that bad however , i am sure someone will take it off you if its in good condition
- macmakkara
I also have one that im going to convert mechanicaln when i have time for that. It also works on win 8 but need little tricks to get it work. Mine is also belkin branded.
- Yslen
- Main keyboard: Poker II (MX Red)
I used to have a Razer-branded one, which I think is essentially identical. I didn't like the domes at all, very mushy. Great otherwise though, most comfortable long-session gaming device I've ever used as it fit my hand perfectly. Thought about picking up the mechanical version a few times but it's super expensive.
I dunno if there where different revisions but i did not mid the domes that much in it . They did have a very soft bottom out yes but they where smooth and nice and tactile
