Change Keyboard layout
s0b
13 Sep 2011, 13:32
Hi all,
Some months ago i bought an Filco Majestouch wich have an US layout. I will change the keyboard keycaps and i want to know if i buy the keycaps for a "european" layout, it will fit in this keyboard?
Very much thanks and sorry my english!
P.D: My first post!
mintberryminuscrunch
13 Sep 2011, 13:41
not all,
the shift keys, enter and the one above enter.
and you`ll notice, that the ansi layout has 104/101 while the iso has 105/102 keys
hemflit
25 Sep 2011, 14:16
What he said. The easiest option may be to get a set of stickers to put over your US keys.
Even then, you will not have the one extra key between left shift and American-Z, which is inconsequential on some European layouts and sort of important on others.
N8N
25 Sep 2011, 14:34
Alternately, you could have WASD make you a custom set of keycaps for your new layout... they've just introduced a new lasering process which is more traditional rather than the previous laser etching.
http://www.wasdkeyboards.com/index.php/
fossala
Elite +1
26 Sep 2011, 15:50
TheKeyboardCo sell (US)ANSI keycaps for the filco as well as (UK)ISO.
grilkip
29 Sep 2011, 01:01
1: Sell ANSI board
2: Buy ISO board
You'll lose around €50 or so due to depreciation and shipping.
cable
01 Oct 2011, 15:36
You could always go for blank keycaps.
I'm using a keyboard with the ANSI layout even though I'm using the Swedish layout in Windows. I find the placements of the keys much better (like the button above the enter key).
When I'm coding I always change to the American layout anyway, as I find them better to code with, even though I'm used to the placements on the Swedish layout (as I'm usually using the Swedish layout when I'm not coding).
The only thing I miss when I'm using an ANSI layout is the key to the left of Z, but I usually just switch between the two languages with Shift + Alt if I want to use ">|<".
So all in all, I'm happy to use an ANSI keyboard with a European layout in Windows.
N8N
06 Oct 2011, 23:05
ISTR that when I hacked up my Filco that the pads for the add'l switches for UK ISO layout were present.
I do not know if the controller is the same or different, e.g. if you just got one new switch and moved the enter and backslash/pipe if it would work or if you'd need to change anything else as well. Since I had an ANSI board and prefer the ANSI layout, I just shrugged and thought "that's interesting" and kept on soldering.
