Switch surgery to create "brown reds"?
- Minskleip
- Main keyboard: HHKB Pro 2
- Main mouse: CM Sentinel Storm
Has anyone removed the bumps on brown cherry switches to make them linear? If it works, you'd just have to acquire a set of browns rather than a set of blacks AND browns to create home made light force linear cherries.
- CeeSA
- Main mouse: MM711
- DT Pro Member: 0016
yeah it's called "ghetto red".
they are a little stiffer than original reds. some (like me) don't even notice the difference touching it first time.
- CeeSA
- Main mouse: MM711
yes i misread, omg - i am too old :/
sorry for this.
measure - i do not measure it.
but i feel it
after a hint looking to the PCB Gaming Switch try Board thread.
in the thread there are some guys thinking that way.
@Minskleip - in germany you could get Blacks for almost nothing. so there is no realy need. But for the rest of the world it might be a good idea.
sorry for this.
but i feel it
- Main mouse: Mickey
They measure the same using the measurement method that must not be named.Soarer wrote:CeeSA, I think you misread the question
But I have one for you - how did you measure that ghetto reds were stiffer? I'd always thought that, if anything, they'd be a tiny bit lighter than real reds.
Assuming you mean a Ghetto Red = Black stem with brown/blue spring.
