Worst switch that you've ever tried?
- keycap
- Main keyboard: '88 Model M, DFK777 SKCM Blue
- Main mouse: A paperclip and a string
- Favorite switch: Alps SKCM, IBM buckling spring
I'm not sure if this thread has been done before, but I felt like making this because I have tried possibly one of the worst switch designs of all time.
The worst switch I've ever tried is a no-name, but it's on an old word processor and it uses a leaf spring over a rubber sheet over a membrane. It should have a clean keyfeel as it is so simple, but it feels absolutely horrendous. Think of Cherry MY, but filled with sand and an even weirder force curve. It's linear in key-feel, but it's very exponential in terms of force. Stabilized keys literally stick and stay down, even when properly assembled; every single key binds (even when you hit them at the dead center at times!), and if you think MX Browns are scratchy, you need to try these. I'm not joking when I say that it literally feels like pencil on sandpaper. And all of the caps are pad-printed thin ABS. I think these leaf springs were used in the terminal keyboard that introduced inverted-T style arrow keys, but maybe the switches are marginally better on it. These switches makes those roll-up silicone keyboards seem like a revelation in comparison.
Post your worst experience with a certain key switch below!
- Redmaus
- Gotta start somewhere
Foam and foil.
It just gets harder as you press down. Really uncomfy. The board has the best keycaps ever though.
- Chyros
Key Tronic tactile foam and foil, Amstrad spring over membrane, and Futaba vintage linear (low-profile and simplified). So far nothing else has even come close to the horrible-ness of these switches.
- DT Pro Member: 0167
I usually find that you can make almost any technology work well, its all about the quality of the materials and the quality of the workmanship. I have felt rubber domes that feel better then some Cherry MX ( am looking at you browns) , some model M BS that feel like crap, some model M that feel amazing. I have used good foam and foil ( with trippleshots)! and some horrible foam and foil.
In general i would go with the worst technology is rubber dome or them chicklet metal keyboards you see in terminals and the likes. But there are good rubber domes.
Even MY in there original black form are not that bad, the modern ones are terrible however.
- seebart
- Offtopicthority Instigator
- Main keyboard: Rotation
- DT Pro Member: 0061
Yeah white MY's are pretty horrible. Really dirty simplified black Alps are nappy but I have tried worse that I can't remember right now.
- cookie
- Main keyboard: HHKB Pro 2
- Main mouse: MX Master
- Favorite switch: Topre
I'd say in this order from worst to less worse:
1. Whatever crap this is: http://farm1.static.flickr.com/7/871612 ... 65.jpg?v=0
2. Cherry ML
3. Cherry MY
4. White Alps, I once owned a HighScreen FK-2002... they were terrible
2. Cherry ML
3. Cherry MY
- seebart
- keycap
Were the White Alps in bad condition? Even a little bit of dust can mess up the switch. Blow dust out of the switch bottom, and don't forget to clean out the switch top. Make sure the metal leafs are clean, and definitely make sure that you reassemble them correctly. For whatever reason, the feeling of an Alps switch depends majorly upon how you clean and especially how you reassemble it. If the click leaf is positioned incorrectly or bent, the switch will feel terrible. And I guarantee that. Give White Alps another chance. I was in your boat a while back when I assumed that Alps were terrible just because the board I received was in poor shape. And now they're some of my favorite switches
- cookie
Actually they were in a terrible condition they had dust everywhere the Caps had a massive amount of shine. The probably caused the terrible typing experience. Some years ago I have settled with my happy hacking keyboard therefore my quest for the ultimate switch stopped. I can only speak of Switches i've tried until then
- Chyros
Not that that's saying much xD .
Good point about the yellow Mitsumis. Although they're not on the same order of magnitude as KT F&F and Amstrad they're pretty horrible to type on xD .
- Touch_It
- Main keyboard: Unicomp Classic USB 103 key (work) IBM F 4704 107
- Main mouse: Logitech g502 Proteus Core
- Favorite switch: Buckling spring (yet to try Beam Spring)
Anything non-mechanical aside, probably a white alps clone board. super scratchy and the switches would bind if you hit anything off-center.
- czarek
- Main mouse: Magic Trackpad 2
- Favorite switch: I have no favourite - I love them all!
For me absolute winner would be whatever it was in Apple M0110A board. Scratchy like a chalkboard and pressing buttons gives me creeps.
Second worst? Either salmon alps in old Apple Extended (because it's pretty much definition of inconsistency, some of the keys click, some are quiet and dapened like quiet Matias, what da?) or White Alps in old Focus board (the switches are actually very, very nice when you press them directly in center, but I touch type, never look at the keyboard when I type and I mostly hit keys off center - that's not a problem on neither IBM, Topre, Cherry, Matias or even Dell AT101 with Black Alps...) Unfortunately when you hit those keys off center, they lock up. For me that makes this keyboard useless.
I must say a lot of rubber dome keyboards are better than those highly regarded (by some) mechanical keyboards I mentioned.
- vvp
- Main keyboard: Katy/K84CS
- Favorite switch: Cherry MX
ZX Spectrum rubber keys were rather bad.
But there are probably no universally bad switches since it looks like some people consider Cherry MX brown to be rather bad and I think they are ones of the best.
- Scottex
- Main keyboard: Realforce 55g TKL
- Main mouse: Logitech G500
- Favorite switch: IBM Beam Spring
cherry ml are quite good for a compact switchcookie wrote: I'd say in this order from worst to less worse:
2. Cherry ML
3. Cherry MY
and wtf white alps are great
- Khers
- Main keyboard: LZ CLSh
- DT Pro Member: 0087
- seebart
- Main keyboard: Filco TKL
- Main mouse: EVGA Torq X10
- Favorite switch: Tactile Alps
Cherry MY, inside of one of those plastic harsh-conditions condoms.
- Redmaus
- Topre Enthusiast
- Main keyboard: Realforce & Libertouch
- Main mouse: Logitech G Pro Wireless
- DT Pro Member: 0002
Non-clicky, tactile Hi-Tek Space Invaders.
I have one keyboard with them and it's atrocious. I'm not sure if it's just the particular example I have being old or something but the binding is just unbearable.
