Hey,
I'm helping evangs organize a (probably small) run of the MiniVan - this time supporting the Aruz switches as well as Monterey/SMK switches.
Since both these switches have an MX/Alps incompatible footprint it's rather hard to find support for them, so we put together a form to see if we can get at least 20 people interested in a kit that'll give you the option of having a very small keyboard with some rather rare switches
Form:
https://goo.gl/forms/CLEJFDcv7AzDF2za2
[IC] AwoozVan - Aruz & Monterey compatible MiniVan
- Favorite switch: Vintage Clears
Hi, I have a Tai-Hao Aruz board with blue aruz switches (Fame TH-5539) and Yes I would be very interested in getting a minivan kit, but in order to accommodate a bit better the switches and Caps is it possible to also provide a correspondent roadkit? This may be asking for too much, but given the scarcity of the caps and corresponding switches, it would seem appropriate to use up as much of the keyboard and caps as possible
- Tuntematon
I'd love an Aruz/SMK compatible board but I really can't get behind the layout, 40% keyboards are just absurd to me. It would be neat to have but I wouldn't use it
- Dra
- Main keyboard: custom cardboard contraption
- Main mouse: Zowie FK1
- Favorite switch: Just let me die already
I'm kind of in the same boat,
- Daniel Beardsmore
- Main mouse: MS IMO 1.1
It's worth noting that you may still be able to buy the MX mount versions:
https://www.aliexpress.com/wholesale?Se ... ard+switch
It's not a guarantee, as the stock may have run out, and some sellers sell you white clicky ones instead of orange linear ones. (It took me a couple of tries before I got actual orange ones.)
However, if you prefer SMK over other brands, you may find this to be a winning combination. (Alternatively, you could use this to get Cherry keycaps on your K110/MiniTouch.)
The linear ones are lubricated and very smooth, by the way.
