DustGod
- Yet another IBM snob
- Main keyboard: IBM Model F 6110344 "Battleship"
- Main mouse: Unbranded vertical mouse
- Favorite switch: Beam Spring | Buckling Spring
- DT Pro Member: 0196
01 Sep 2017, 11:57
Hi! I'm trying out a left-handed vertical mouse:
I'm right handed. I'm three days in now, getting a bit more natural but it still feel quite clumsy to work with.
Anybody have experience on that? How steep can I expect the learning curve to be?
- Main mouse: Logitech G700s
- DT Pro Member: 0224
Contact:
01 Sep 2017, 13:30
I tried that a few years ago (but with a regular mouse, not a left-handed one). Took me a couple weeks to adjust, but wasn't hard. I then went back for no real reason and haven't tried again — perhaps I should.
- DT Pro Member: 0011
01 Sep 2017, 17:24
I have owned a left-handed vertical mouse only for a week, but I regularly use right-handed "vertical" mice.
For me, it was the different-handedness that was the hardest to get used to, not that it was vertical.
MajorMajor
- Main keyboard: WASD 87 Custom v2
- Main mouse: Anker Vertical
- Favorite switch: Cherry MX Clear
Contact:
02 Sep 2017, 03:13
Did you go with the left hand for ergonomics?
It took me 2-3 months to get back up to speed switching from QWERTY to Dvorak keyboard layouts, I think that would be a much longer process than changing mice hands. I use a righty Anker which only took a few days to get adjusted to - best of luck.
DustGod
02 Sep 2017, 18:42
MajorMajor wrote: Did you go with the left hand for ergonomics?
That, and optimal keyboard-mouse combination.
I should mention that it does not matter if the mouse is vertical... I think. I've been using a right-handed vertical mouse from more than 6 months now; I could use it almost as fast as a regular mouse right off the bat.
hoggy
- Main keyboard: Kinesis Advantage
- Main mouse: 3M Vertical
- Favorite switch: MX Brown
- DT Pro Member: 0009
09 Sep 2017, 23:04
Just keep going. Vertical mice (left or right) feel really clumsy at first, and after a few years I'm still faster with a flat mouse in my right hand, but after a while that would start to hurt. In my my, the transition was well worth it.
- Elder Messenger
- DT Pro Member: 0158
13 Sep 2017, 14:23
To me, true "vertical" mice are no good but 45-degree mice are about ideal.
I have used right-hand vertical mice for several years, but I keep a standard symmetrical mouse (Microsoft Optical) on the left side.
13 Sep 2017, 16:53
Some years ago I used a right-handed Evoluent every day at work. The biggest annoyance for me was not the shape but that that mouse "corrected" vertical and horizontal movements to be precisely vertical or horizontal. Having moused for most of my life I had a feel for where the pointer was supposed to be when I moved it.
I don't know if they have changed it since in newer models.
Berp123
- Main keyboard: Magicforce 68
- Main mouse: Razer Naga 2012
- Favorite switch: Zealio Purples
13 Sep 2017, 18:15
I think left handers are the devils children and should be killed
- Main mouse: MS IMO 1.1
Contact:
13 Sep 2017, 19:58
Here, lie down on this couch. Now, tell me about your mother …
DanielT
- Un petit village gaulois d'Armorique…
- Main keyboard: Various custom 60%'s/HHKB
- Main mouse: MS Optical Mouse 200
- Favorite switch: Topre/Linear MX
13 Sep 2017, 20:23
Daniel Beardsmore wrote: Here, lie down on this couch. Now, tell me about your mother …
It's not the mother.... the problem are the Zealios, they are known to cause dementia ....
Contact:
13 Sep 2017, 20:32
Maybe trying to distinguish those subtly different shades of purple slowly damages the mind …At least we're no longer blaming Alps for insanity.
Contact:
13 Sep 2017, 20:46
s/blaming Alps/blaming only Alps/
(amirite?)
rich1051414
- Main keyboard: Whitefox Zealios 67g
- Main mouse: Logitech G900
- Favorite switch: Alps Orange
22 Oct 2017, 16:23
Vertical mice sacrifice speed and precision for comfort. Personally, even after using a vertical mouse for months, when I switched back to a flat mouse, I was both faster and more precise with my clicking, but less comfortable. However, perhaps my experience is anecdotal.
ckofy
29 Oct 2017, 19:38
rich1051414 wrote: Vertical mice sacrifice speed and precision for comfort. Personally, even after using a vertical mouse for months, when I switched back to a flat mouse, I was both faster and more precise with my clicking, but less comfortable. However, perhaps my experience is anecdotal.
I agree to you, my experience is similar. I could not be the same precise with vertical mouse as with the regular one even after a weeks of using it.
- Elder Messenger
29 Oct 2017, 20:14
Were either or both of you using the horrible Evoluent mouse? In my opinion, that is the worst mouse ever made, impossible to control and wretchedly uncomfortable.
Try a 45 degree mouse like the Anker or Joy Pen before you give up completely.
Pumaeggs
- Main mouse: Intellimouse Optical 5 button
05 Oct 2018, 16:15
oh shit what's that funky layout on your model M? i'm assuming it's a lexmark, is it a terminal model like an M-122? i'm loving the combo though
