Hello again,
I'm trying to complile the Soarer's utilities for linux. I have extracted Soarer_sctools_v1.10_source.zip to a new, clean folder. In a linux terminal, I've issued "make" and the name of the Makefile in the Linux subfolder. No errors, but I'm not sure where to find the executables, or even if they were created at all.
Any ideas, anyone? Does this need to be done in a Windows environment, and if so, with what tools?
Apologies in advance if this is beyond the scope of these forums.
Thanks!
Compiling Soarer's converter utilities
I can’t speak for Linux but I did compile them myself many years ago on the Mac. I wanted PowerPC support, and I got it. Don’t remember anything particularly difficult.
Why not use the prebuilt utilities? Vaguely remember Linux files being there. Could be wrong though, it’s been forever since I started.
- Main keyboard: Omnikey Ultra
- Favorite switch: Blue Alps
Well, the reason I needed to recompile, is that the pre-built ones don't run on Linux 64 bit, only on 32-bit, even after installing 32-bit compatibility libraries from the Linux distribution.
However, running Make from the first-level folder in the tools (under the "source" folder) did compile them successfully.
THANKS!
THANKS!
- Saltarello
- Main keyboard: OmniKey 102
- Main mouse: Apple Track Pad
- Favorite switch: Alps Blue/IBM Buckling Spring/Don't ask me this!
I need to compile Soarer's utilities for Catalina. I'm not a programmer. I can compile a hello world successfully in Terminal. But when I try to recompile Soarer, I get "bad CPU type in executable".
Can anyone clue me in on how to fix this?
Thank you kindly,
S.
Thank you kindly,
S.
- lhutton
- Main keyboard: Model M
- Main mouse: Whatever's handy
- Favorite switch: Anything not butterfly switch
- DT Pro Member: 0243
It's been a while and I don't have a Mac on Catalina now. I've had to make some changes to where it includes libusb/libusbx from to get it to compile on Debian 10 or Fedora. Have you changed your shell type form bash to zsh? I don't know if Bourne is included in Catalina since Apple has been purging GPL software. The lone couple of Macs I have kicking around are still on Mojave for legacy compatibility and I don't really use them every day.Saltarello wrote: 28 Dec 2019, 20:45 I need to compile Soarer's utilities for Catalina. I'm not a programmer. I can compile a hello world successfully in Terminal. But when I try to recompile Soarer, I get "bad CPU type in executable".
Thank you kindly,
S.
- Saltarello
I upgraded to zsh as Apple nagged. I also updated cpp to the latest. So I think the system is good. It can compile and run a simple program error free.
I think I'll concentrate on locating where the CPU type is specified in the Soarer source and what it needs to be changed to.
Was hoping someone here could point this out. But hopefully it won't be too tedious to figure out.
- Main keyboard: F122
- Favorite switch: IBM Beamsprings
This might all your problems: https://github.com/Kreeblah/sctools_macosSaltarello wrote: 02 Jan 2020, 18:50 I upgraded to zsh as Apple nagged. I also updated cpp to the latest. So I think the system is good. It can compile and run a simple program error free.
