ACK60 3D printed (AEK but compact)
4sStylZ
17 Feb 2021, 10:44
Hello there,
8 months ago I was doin some keyboard projects… and stopped them completly. Burn-out of kb things lol.
I just took some time to release one of my project : ACK60% ANSI (AEK… but compact and 3D printed…)
My approach is very DIY. I want to do my maximum to achieve home made. This one was the first to support underglow with a 1mm layer of epoxy resin in the back.
The plate is my best result so far in term of use. it's 7,9 mm thick, and with 100% infill that's rigid and sound proof unlike metal ones. I will probably make an ISO version soon… but's that's a long process for me.
Here are the files : https://www.thingiverse.com/thing:4763441
What's inside the box ?
- A 60% tray mount case designed to be used with Epoxy resin to have underglow on the back.
- A plate for compatible PCB (ALP64 and others AEK compatible PCB).
- A plate designed to handwire.
- A plate designed to use a postage board or Postage mini.
- A Wristrest.
- Multiples varations with splitted parts to suit small 3d printers.
melka
17 Feb 2021, 19:34
Nice work man ! Reminded me of the micro AEKII case on thingiverse but your's is nicer imho
Do you have more pictures of the real case ? And are you planning on printing in another color / painting ? The dark grey rendering looks real good.
https://www.thingiverse.com/thing:2740927
andreas
17 Jun 2021, 10:14
Great project and very inspiring.
Bjerrk
17 Jun 2021, 11:18
4sStylZ wrote: 17 Feb 2021, 10:44 The plate is my best result so far in term of use. it's 7,9 mm thick, and with 100% infill that's rigid and sound proof unlike metal ones. I will probably make an ISO version soon… but's that's a long process for me.
Amazing! Dunno how I managed to miss this the first time around.
Did you ever work on an ISO version? :)
