This repo has most of the project files: https://github.com/jsheradin/3m_whisper The scans I took are too high res to upload easily.
Pictures:
I mostly followed this guide https://github.com/ruiqimao/keyboard-pcb-guide except that I just used a Teensy library in place of doing a full controller onboard. The most time consuming part is loading up the scans of the original PCB in Gimp and taking a million measurements to get the positioning just right.Rayndalf wrote: 16 Mar 2021, 07:56 Any insight into how you make these? I have a couple obscure boards I'd love to be able to retrofit, and spending $50 on a batch of PCBs is so much nicer than spending several hours handwiring.
I'm looking forward to a guide, in the mean time I'll try to brush up on CAD and Eagle (or Kicad or...)jsheradin wrote: 16 Mar 2021, 17:23I mostly followed this guide https://github.com/ruiqimao/keyboard-pcb-guide except that I just used a Teensy library in place of doing a full controller onboard. The most time consuming part is loading up the scans of the original PCB in Gimp and taking a million measurements to get the positioning just right.Rayndalf wrote: 16 Mar 2021, 07:56 Any insight into how you make these? I have a couple obscure boards I'd love to be able to retrofit, and spending $50 on a batch of PCBs is so much nicer than spending several hours handwiring.
I'm planning to do another board pretty soon so I'll try to make a guide as I go.
Good luck with the Geac! I've been using mine pretty regularly and have been really enjoying it (I'm a sucker for sphericals).
