Hello everyone
I was just wondering if anyone had any pointers on designing a pcb for cherry mounted switches. I would only need a matrix as i would use a Teensy for the controller.
I was thinking of something like an N52 but home made as i don't want to modify the n52 as i think i can do a bit better.
Unless someone knows of something i can buy pre made that is say a 5 x 5 matrix ( like a point of sale programmable but smaller)
Designing a cherry PCB
- Main keyboard: 4704
- DT Pro Member: 0186
http://github.com/redvers/isokeyboard
Some example PCBs there.
I'm actually building up an ansi IBM Model M layout PCB for my own experimentation. After I've finished routing it I'll post it here to let you know.
- DT Pro Member: 0167
thanks for the update guys will take a look when i get home .
now i just need some cherry MX reds and some caps
