Cherry MX greens: worth it?
- csimi
Are these switches worth it? I loved my buckling spring keyboard but it was too old-fashioned so it had to go.
I assume MX greens would please even some heavy bear-hands?
Also, would these be okay for gaming? Has anyone tried a keyboard fully loaded with them?
- DT Pro Member: 0011
There are a few people who have modified or built custom keyboards to have only greens, yes.
The tactile bump is the same as on MX Blues, but because the spring is harder the tactile feel is relatively diminished.
MX Blues and Greens have hysteresis, just as the buckling springs, and some gamers don't like it.
If you were happy gaming on buckling springs, the greens should work for you. It depends on the games you play and your style of using the keyboard when playing those games.
BTW, have you looked at Unicomp's buckling spring keyboards in a smaller case? They are practically the same internally as the old ones, but the case is slightly smaller, available in black or Mac version and you can now choose to have one with USB and/or a trackpoint.
- damorgue
- Main mouse: MX500
- Favorite switch: BS, MX Green and MX Clear
Correct me if I am wrong, but I don't think buckling springs have any hysteresis whatsoever since they register when the spring buckles, which is the same mechanism that determines the tactile feedback?Findecanor wrote: MX Blues and Greens have hysteresis, just as the buckling springs, and some gamers don't like it.
- win
- Main keyboard: Unicomp Spacesaver
- Main mouse: G9x
- Favorite switch: toggle
Yes, I thought hysteresis was an MX Blue (Green) thing. If BS do have it, it's much less pronounced. I've used both, and it's very detectable in Blues. With Blues, I think o-rings help a lot. They also prevent the bottoming out clack.
- Favorite switch: MX Red
I made a gamer pad out of a Access IS 14x6 modded to ghetto greens as an experiment and I liked it for a little bit. I do really prefer softer switch like reds primarily, so take what I say for what it may be.
It has it's plus and minus from blues, which I do also use occasionally. While I do really like blues/greens for certain things, they do have their hiccups in fast action games where you need to 'spam' a key, as the reset is a little off from the bump, as you would hopefully now be aware from the prior posts. However the hysteresis can become used to in some instance with acclimatization to the switch, so it may or may not be an issue to the individual. I quite miss my custom Access gamer pad, and wish I would have held on to it now, but a nice trade deal of a Leopold FC200R with reds got the better of me. C'est la vie.
- Kurk
- DT Pro Member: 0027
They do have hysteresis since the activation point and the de-activation point are different.damorgue wrote:Findecanor wrote: ...
- Soarer
- Favorite switch: F
I forget... what's the difference between greens and modern whites?
The whites seem to be somewhat available... I didn't really get on with them though, at least, not on my weakling pinkys! Blues with clear springs would be the closest (but not massively different from blacks).
- Trent
- Main keyboard: IBM Model M
As someone who loved the buckling spring mechanism, I found mx blues to feel cheap and flimsy. Mx greens have a bit more force but don't compare at all. That being said if you like the feel of mx blues and want something requiring more force mx greens are the way to go.
- Main keyboard: Das Ultimate Silent
- Main mouse: Logitech Trackman
- Favorite switch: good question!
hmm, didn't think of that, but Cherry sez black is the same force as blue. Clears are a little bit more but only greys and greens have the crazy forces.tinlong117 wrote:mod it with blue stem and black springpossum wrote:This would be interesting to try, but where to get so many greens? Mouser seem to have 0 in stock.
Ballpoint springs might be worth a try. This place has them by the 50, though i don't know how strong they'd be. The BPS1 model seems to have the right diameter.
- dorkvader
- Main mouse: CST 1550
I just took apart my greens and whites and here is a list of differences I saw:Soarer wrote:I forget... what's the difference between greens and modern whites?
Greens have green stems and white "clickers" (not sure what that's called. It slides and provides the click)
Whites have white stems and black "clickers"
I measured the springs, and they look completely identical. I also closely examined the "clickers", and they also appear to be the same.
Since I prefer the colour green to white, anyone want to buy my 100 or so plate mount whites?
- damorgue
- Main mouse: MX500
That quote made me realize just how picky of a community we are. After a post which explains that they are the same, the colour of the stem hidden underneath the cap still matters, not because it is different but just that one prefers to have a certain colour.dorkvader wrote: Since I prefer the colour green to white, anyone want to buy my 100 or so plate mount whites?
- dirge
Dude, clickclacks. Having the right colour is like life and death!damorgue wrote:That quote made me realize just how picky of a community we are. After a post which explains that they are the same, the colour of the stem hidden underneath the cap still matters, not because it is different but just that one prefers to have a certain colour.dorkvader wrote: Since I prefer the colour green to white, anyone want to buy my 100 or so plate mount whites?
- webwit
- Wild Duck
- Main keyboard: Model F62
- DT Pro Member: 0000
I hope with matching green invisible switch stickers, otherwise it would be lame.damorgue wrote:That quote made me realize just how picky of a community we are. After a post which explains that they are the same, the colour of the stem hidden underneath the cap still matters, not because it is different but just that one prefers to have a certain colour.dorkvader wrote: Since I prefer the colour green to white, anyone want to buy my 100 or so plate mount whites?
- damorgue
- Main mouse: MX500
Well, CCs you can actually see in normal use, but yeah, we are a picky bunch.
- Main keyboard: Filco TKL with Red or Blue
- Main mouse: Logitech G500
- Favorite switch: Cherry Red, Blue, Vintage Black, Topre
wait are you sure they are identical? according to ripster force test not: http://i.imgur.com/z0iCr.jpgdorkvader wrote:I just took apart my greens and whites and here is a list of differences I saw:Soarer wrote:I forget... what's the difference between greens and modern whites?
and what about the sound? i've tested whites and blues and the blues are way louder. white's have the "soft" click and its easier to activate. how does that compare to greens?
i'm interesting in buying your whites. don't want to wait so long on 7bit's preorder. where would you be shipping it from?
