Is it possible to use a matrix for the diodes, or does every diode need its dedicated connection to the controller?
I found this somewhere and wonder if it works with a teensy or teensy++ controller:
Yes, seems so. Thank you for that link. I think it will be the way I'll do it. If someone needs it more fancy it is still possible to wire them up manually.tlt wrote:Sorry, Im tired I guess that matrix is the same thing.
Don't see the point. I conquered the keyboard itself, now I can add some fluff to sell more.Soarer wrote:It was painful enough watching you start to design PCBs, but this is really making me want to scream STOP! now
Sorry to be so blunt.
If it was just you doing it for yourself I'd be all for it.
But for a group buy? No. Really. This is getting ridiculous.
