So... as the title states, why is this keyboard so hyped up?
I've been typing on mine for a week. It not a "bad" experience so far, but a far stretch from being the amazing board people make it out to be.
My (mostly minor) issues are:
1) The spacebar is pretty loud for a "silent" model, especially when activated with your right thumb at certain angles. It makes a sharper clicking noise. I expected better quality on the spacebar, backspace, and shift keys. I don't think there's any defects with this model, the larger keys are all fairly similar.
2) The spacebar felt a bit heavy/mushy. I've removed the spring from it and applied a very tiny amount of dry teflon lube to the two internal guides. This made it better, but it's also even louder now
3) I touch-type most of the time, especially for normal dialog, but when writing code I'll sometimes start favouring my index and middle finger I'm not sure why I do this, but it makes the whole variable weight key thing a bit annoying. The uneven weighting becomes much more obvious.
4) The keyboard and keys feel way too tall for me. I sort of assumed it was similar in height to most rubber-dome models, oops. I think modern apple keyboards have ruined me. Do I really need a wrist wrest? that seems so 1990's.
Being honest, as is stands now I wouldn't rate the typing experience as being much better than a decent rubber-dome keyboard model.
I have used mechanical/traditional keyboards before. There was one with Cherry Brown switches I liked, I didn't notice the keys and keyboard height being so height. I feel like I need to carve a hole out of my desk to place this keyboard inside.
I was previously using a stock Apple wireless board (several years), your typical flat scissor-switch keys. I was fairly happy with this, but suffered from accuracy issues when typing quickly for longer stretches, probably due to such flat keys. Now I'm starting to question what sort of keyboard/switch I actually like. I read up on the Topre switches and other options for at least a month before making the jump, they sounded like a good match.
Perhaps I need something in-between? A lower profile keyboard with snappier short-travel keys? maybe.
I'm a bit concerned that I won't adapt, or at least not quickly enough for the Realforce to be practical. I'll give it my best shot. Your input/advice is appreciated.
If my wife sees me typing on the old Mac BT keyboard, I'll be in big trouble...
