This is a (hopefully) more determined continuation of this thread: http://deskthority.net/workshop-f7/desk ... t4651.html
I will try to step in as a manager of this project *brings out the whip*, however: I do not deserve any credit for the actual design work, if you should thank anyone, thank matt3o who's working his ass off in this thread: http://deskthority.net/workshop-f7/refi ... t5266.html
Now onto the keyboard:
In the title i've just referred to the board as "DT68A"(DeskThority 68-key Alps) This is so that we can have a project name instead of saying "that alps keyboard" all the time.
Regarding the board itself; there hasn't been all too much work on the Alps board itself, except for what that is mentioned in Matt3o's thread. Hopefully this will change soon.
Stay tuned!
DT68A Project
- matt3o
- -[°_°]-
- Main keyboard: WhiteFox
- Main mouse: Anywhere MX
- DT Pro Member: 0030
Okay we have 3 options here:
1) make a 15x5 layout with all keys lower than 2u such as this
PROS: Signature Plastics has all the molds for that and we could make a 65% layout
CONS: No standard keys, you can't use your old ALPS keycaps for it. No ISO layout possible.
2) make a 60% standard layout (poker like)
PROS: you can use any standard ALPS keyboards for keycaps
CONS: no 65% layout
3) make a 65% 16x5 layout
PROS: ISO layout possible. It should be possible to recycle your old alps caps. maybe not 100% fancy but should be doable (maybe we miss the right shift?).
CONS: we need a lot of stabilizers. We would need a lot of new tooling from SP (so a very high volume of orders) if we want to produce new keys
no easy answer here.
CONS: no 65% layout
