RetroBright experts?
- Half-Saint
- Main keyboard: Raptor Gaming K1
- Main mouse: Logitech G5 Mk.2
- DT Pro Member: 0058
Anyone here experimented with RetroBright? I'd like to remove yellowing from a bunch of keycaps...
- The Solutor
- Main keyboard: Xarmor U9BL-S
- Main mouse: Logitech M705
- Favorite switch: MX Clear
I think that the good old cocktail (50% ammonia, 50% Hydrogen peroxide) should be the better option to clean old plastics.
And it's also relatively cheap.
- Main mouse: Mickey
Retrobrite Rulez. Hydrogen peroxide might make the plastic brittle.
http://geekhack.org/showwiki.php?title=Island:9099
The video embedding code here is primitive
- The Solutor
It's unlikely.
Most of the "delicate" laundry bleaching products are based on Hydrogen peroxide or Sodium perborate, or both.
The cocktail I mentioned is also used since the stone age to clean the antique wood w/o hurting it.
I think that the best way is using the mentioned cocktail just for few seconds or few minutes depending on the plastic conditions, then washing it with a lot of water, then drying, then using a wood care spray wax.
The jonson's wax one, is called "Pronto" in Italy, i don know if the same name is used outside Italy.
- The Solutor
It's just 15 year of work in almost any electronic sector + 15 years of IT technician + 2 years of antique furniture restoring + a bunch of hobbies.
Usually the experience matters, in Italy, as in US.
Hahaha - I just realized that's a bottle of hydrogen peroxide in my picture.
Anyhoo - it DOES work better with some UV.
It's a chemical reaction Free The Radicals thing.
- The Solutor
They are all oxidizer, they are doing, more or less the same thing.
And they are more handy than some other oxidizer, like this...
- Peter
- Main keyboard: Steelseries 6Gv2/G80-1501HAD
- Main mouse: Mx518
- Favorite switch: Cherry Linear and Buckling Spring
No it isn't, your picture depicts a hairdresser product.ripster wrote:Hahaha - I just realized that's a bottle of hydrogen peroxide in my picture.
It contains additives suitable for (dead) human hair .
ABS-plastic isn't hair !
