I have a Kinesis Freestyle. I remapped capslock to spacebar, but it would be better to remap the left spacebar te capslock, and use the right spacebar for space.
But these two keys have the same code: 57.
is there any way to remap it, using autohotkey for instance? I have to get a difference between the two keys, somehow.
Help would be greatly appreciated!
Remapping left spacebar (to backspace) on a split keyboard
- Input Nirvana
- Main keyboard: Kinesis Advantage
- Main mouse: Rollermouse Free2
A-
There is an issue with your goal of re-mapping one of the 2 spacebars, both keys send the same scan code. I've dealt with Kinesis regarding this 1.5 years ago. I believe there is a firmware change/upgrade, you need to email Rick in technical support. I was going to do this, but wound up not changing the firmware. I really like the Freestyle, I've used both PC and Mac.
- Main keyboard: Compaq mx 11800
- Main mouse: Logitech
- Favorite switch: cherry brown
Hi, I sent an e-mail and got a reply from Rick. He's willing to change the firmware, that would do the trick, but then I would have to pay the shipping costs to and from the USA. That would be a bit pricy. I got the Freestyle for 32 euro (including shipping and the Incline set-up) from a guy here in Holland.
So it's a nice offer from Rick but I won't take him up on it.
I'll use autohotkey to remap backspace to shift space on the freestyle, that will work fine.
I presume changing the firmware is not something I can do myself??
- sixty
- Gasbag Guru
- Main keyboard: DKSaver
- Favorite switch: Cherry MX Black
- DT Pro Member: 0060
If they can change the firmware as easy as that - there is probably a simple EEPROM chip inside. Maybe you can ask them to send you just the IC with the update firmware? Alternatively, this could be done with a pretty easy hardware job, if you know how to solder.
- Input Nirvana
In the past, I think they have sent the parr to people in Europe. Maybe they don't choose to do that anymore. Definitely ask.
Another idea is to have someone in the US get the firmware change in a Freestyle and ship to you. Them sell the Freestyle you have.
Just thinking out loud.
- webwit
- Wild Duck
- Main keyboard: Model F62
- DT Pro Member: 0000
Buy a Model M15 and get it over with.
- Input Nirvana
There are lots of ways to skin Schrodingers catwebwit wrote:Buy a Model M15 and get it over with.
Both the M15 and Schrodinger's cat are a bit out of my league... but thanks for your comments!
in the meantime still happy with Shift spacebar for backspace. I'll ask Rick at Kinesis what he can do.
