Sixty, Webwit, feel free to delete this post if it's already been posted.
I'm not a fan of Filco nor Leopold, but have you counted how many keyboards are looking the same as the model M ?Meh, too easy. It is clearly a product called into life because of the success of the Filco. I bet they started with the Filco, and then thought, hmm, we can't have the case exactly the same or we'll get legal problems, gave it the asymmetrical (only on the top) curvy edges, which is exactly what makes it look relatively cheap and ugly compared to the clean, straight lines of the Filco case.
Gilgam wrote:nice !!!
did you cut some silvered paper and paste it ?
or is it spray painted ?
Yes, these are horrible clones as well. Unless you noticed them looking like the Model M before the Model M was released. I think before that they cloned the Model F look.The Solutor wrote:I'm not a fan of Filco nor Leopold, but have you counted how many keyboards are looking the same as the model M ?
You are right. They are CNC laser cut metal foil.The Solutor wrote:Gilgam wrote:nice !!!
I think he just know someone with a cutting plotter
