I like the yellowish vintage look, the heavy used spacebar every single scratch on it.
You can see the whole cleaning here: http://deskthority.net/photos-videos-f8 ... t6955.html
The keyboard has this "Undestroyable, always reliable" aura and I believe it is not even a lie
Okay, now here is something I noticed right away.
You need a lot more force to press the key down, a positive effect is that this keybaord has a nice and deep "thok the downside of this is that I feel a fast fatigue typing on it, so am not using it atm.
I buildet a quick ripOmeter to check if my assumption is true. I used 15x10 Eurocent coins with a total weight of 61Gramm.
On my pro2 it is totally enough to press the keys, even the spacebar which has the spring installed.
On the Pro1 there is no chance to press the keys down
Can someone confirm that topre domes stiffen over time?
Maybe a solution for this problem?
Thanks a lot!
