Backlight demo Layers
Unboxing
http://imgur.com/a/yMWqX#0
Agreed. Although the present model is not my cup of tea, I look forward to seeing the Matias-switch versions. It is good to see a vendor in addition to Matias using the Matias-tactile/click and Matias silent switches.Muirium wrote:I've tried WASD and ESDF arrow keys before (still got the latter as a left handed backup) but the HHKB arrow key diamond is so far ahead there's no comparison. It needs a short right shift to really fly, mind, but that's what I expect of every 60%, and a 1.5u Backspace where it ought to be instead of wasting two keys at the top!
Will be available in both! And it will fit in Poker cases, just some screws will not align fully and 2 of the 6 DIP switches are covered. We'll be stocking Green and Clear.SL89 wrote:I haven't ever been exited for a 60% board until i saw everything about the V60. I keep seeing conflicting reports regarding its availability with MX White AND MX Clear. Will this be compatible with most 'Poker' style cases?
Good to hear, thanks for clarifying!QWERTim wrote:Will be available in both! And it will fit in Poker cases, just some screws will not align fully and 2 of the 6 DIP switches are covered. We'll be stocking Green and Clear.SL89 wrote:I haven't ever been exited for a 60% board until i saw everything about the V60. I keep seeing conflicting reports regarding its availability with MX White AND MX Clear. Will this be compatible with most 'Poker' style cases?
you should have both. I want a kb with a space splint into 3 - two 2,5 u keys, space and fn, and a 1u fn lck in the middle.
