Help me identify this Keyboard
aaronkatrini
06 Oct 2022, 11:30
Hi all,
Recently got this nice AT Keyboard, gave it a quick test and seems to be working fine, but I'm having a hard time identifying it.
Here are some photos:
https://drive.google.com/drive/folders/ ... sp=sharing
Does anyone recognize it or what switches it uses? Thanks in advance :)
doomsday_device
06 Oct 2022, 11:32
wiki/Datacomp_DFK191
high chance of white alps, but can also be smk or futaba ma.
edit: didnt clicked the link, looks like alps dws
06 Oct 2022, 11:34
Link doesn't work for me. (Seems to be for collaborating, not just viewing the files. In any case, they won't just load so I can look at them.) Got switch pics?
aaronkatrini
06 Oct 2022, 11:38
Muirium wrote: 06 Oct 2022, 11:34 Link doesn't work for me. (Seems to be for collaborating, not just viewing the files. In any case, they won't just load so I can look at them.) Got switch pics?
https://imgur.com/a/2evmm63
Just uploaded to imgur :)
06 Oct 2022, 11:42
Well, that ain't no Alps beyond the mount.
My connection's being throttled while I upload a bunch of work, so the DT wiki's barely loading for me. But this is the place to start.
Polecat
06 Oct 2022, 17:19
Datacomp DFK-171. Slider-over-something, not discrete switches. This shared the case styling with the DFK-121 (Futaba) and DFK-191 (Alps/clone).
edit: actually DFK-172 since it's the ISO version.
aaronkatrini
06 Oct 2022, 19:05
Thanks all for the suggestions :)
@Muirium, I tried the link but couldn't find an exact match.
@Polecat, your suggestion seems to be correct. I'm not familiar with Futaba switches, but I don't think it feels quite an Alps. I no longer have an Alps kb, but from memory it feels different.
06 Oct 2022, 23:23
It’s non-mechanical, like Polecat says. Not surprising it’s also not in the wiki. Someone would have to care enough to take up its cause.
zrrion
07 Oct 2022, 02:53
on the other hand, documenting it on the wiki or somewhere else easily searchable means that other folks can steer clear of it easier
Polecat
07 Oct 2022, 06:03
aaronkatrini wrote: 06 Oct 2022, 19:05 Thanks all for the suggestions :)
Here's the black version on ebay:
https://www.ebay.com/itm/254786446460
Definitely not Alps or Futaba. The DFK-171/172 was the cheaper version with sliders and a one piece plastic plate, and probably a membrane underneath. The 1u caps should be Alps-compatible, but I'm not sure about the stabilized ones.
